Code for moving number to another provider
Discussion in 'Mobile Phones Forum' started by badsoden, Jan 22, 2008.
Thread Status:
Not open for further replies.
  1. badsoden
    badsoden
    Jan 26, 2007
    531
    Nottingham
    +16
    I need a PUK code to transfer my number, is that right? Also do I have to wait for the end of my contract to ask for one or can I ask in advance? Does the code have expiry limit on it?
  2. james_uk9
    james_uk9
    Dec 9, 2005
    758
    Cardiff
    +28
    It's a PAC code you need, not a PUK code. They usually expire after 30 days with most networks. You don't need to cancel your contract, the PAC code takes care of that should you use it to join another network.
  3. badsoden
    badsoden
    Jan 26, 2007
    531
    Nottingham
    +16
    Sorry yes PUK codes to tranfer to another ISP!!
    Thanks for that. If i want things to be as quick as possible do you have any advice on how to handle it?
  4. Vini
    Vini
    Nov 25, 2005
    1,608
    48
    UK
    +66
    Call your current Network, ask for your PAC.
    Call the network you wish to join, advise them you wish to port your number. Provide them with your PAC.
  5. 3T3L1
    3T3L1
    Aug 6, 2005
    810
    46
    +104
    you also need to do it within 30 days of getting your code or your old contract will carry on in parallel with your new one, and your old number will be kept associated with your old contract.
    make sure you chase it up as O2 screwed mine up and I had to pay another 2 months on Orange before it all got sorted.
  6. fawcepi
    fawcepi
    Dec 11, 2007
    115
    North East
    +19
    You can ask in advance but you may have to pay off the remainder of your contract before they issue the PAC Code. Thats how Orange work anyway.
    Thats because you'll effectively be cancelling the contract. If you get the PAC code within the last 30 days of your contract there wont be any extra charge.
  7. hutch
    hutch
    Jun 29, 2006
    6,660
    Perth, Australia
    +1,224
    Think this has run its course now, your provider will give you all the info you need when you apply for your PAC.
Thread Status:
