Code for hacking Philips 957 dvd player
Discussion in 'Home Cinema Control & Remote Controls' started by Timh, Aug 4, 2002.
  1. Timh
    Timh
    Sep 14, 2000
    4,824
    Altair-4
    +140
    Can anyone help me set a code for hacking a philips dvd player, heres the instructions from dvd reviewer, I take it that I can programme my pronto to do it but I dont no how.
    Send the infra-red code RC6 (aka Codeset 4, Key 235 in nerd-speak) to your player. You can do this with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 Digital with the following instructions:
    Configure your remote using the setup code 0539
    Press the Magic button
    Enter the code 085
    If you own a Palm Pilot, you may also use Pacific Neo-Tek's OmniRemote software to generate the RC6 code using a downloadable .pdb file.
    Download the .pdb file into your Palm Pilot
    Press the OmniRemote key marked as 955 Multizone
    If you do not own either of the above units, it is possible to construct a cheap DIY solution by following instructions at the following website.
    2. The onscreen display should show 11 spaces like this: '-----------'
    3. Using the number keys on your DVD player's remote control, enter the code 222 222 005 255. Note that this is 12 digits and the last digit will not show on the on-screen display.
    NOTE: For players such as the Philips DVDR-980, DVDR-985 and DVDR-1000 units, you will need to use the code 121 212 005 255 instead.
    4. Press the Play button on your DVD player's remote control
    5. The onscreen display should now show the words No Disc
    6. Power off your DVD player, wait 10 seconds and then power back on
    Thanks for any help.
  2. Kitch
    Kitch
    Apr 18, 2001
    557
    46
    Nr Sheffield
    +151
    i hope you can follow this.
    i think you can only get the rc6 code using pronto edit version 1
    set yourself a new panel and button up
    double click the new button and select the action tab
    click on rc5/6
    highlight rc6 mode 0
    in the system box enter the no.4
    in the cammand box the no. 235
    download the new config. into pronto
    press the newly adopted button for the phillips player to recieve
    then follow the instructions from no. 2
    sorted
    all the best
    mick
    http://uk.photos.yahoo.com/kitch_homecinema
  3. Timh
    Timh
    Sep 14, 2000
    4,824
    Altair-4
    +140
    Kitch
    Thanks, I am using prontoedit4 so I will have to have a look round for the old version.
  4. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    I should be receiving my new Pronto tonight, and will be wanting to use it to hack my Philips 963SA when that arrives.
    I'll be needing to generate an RC6 code as above to do that, so my question is;
    - Does only V1.0 of Pronto Edit work for this, and if so where can that version be downloaded from ?
    Thanks in advance,
  5. Timh
    Timh
    Sep 14, 2000
    4,824
    Altair-4
    +140
    Monty
    I made the RC6 code with prontoedit4 but haven't tested it as i do not own any Philips players, I needed the code for my Brothers player which was faulty and went back to the dealer before testing the code.
    If you like I will send you the code as an attachment if you PM me your email address.
    V1.01 is available from here
  6. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    Thanks Tim . . . if it's works in Pronto Edit V4 I'll just use that, no need to search out V1.
    You have a PM.
    Cheers,
