coaxial or optical ?
Discussion in 'AV Receivers & Amplifiers' started by pezzer, Jul 20, 2004.
  1. pezzer
    pezzer
    Jun 9, 2004
    190
    West Sussex
    I am changing my dvd player - at the moment I have to use optical digital out to my Kenwood kRF 5030 receiver. My new player only has coaxial digital out.
    Will this audio signal be as good / better than optical and do I use a standard good quality phono lead for the digital coaxial connection?
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    If you want to use the phono style connection you need to make sure the cable is 75ohm for digital. Normal audio phono leads are 50ohm and should not be used.
    As to which sounds better, coax or optical, only you will know if you try it out with you own setup.
  3. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,663
    In an absolute sense, the coax should be better than optical although at most normal levels it really doesn't make a huge difference. A phono cable will do the job but I would recommend the digital cable available from Mark Grant in the Powerbuy section as these are stonking for £20.
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Totally agree with Tons. Superb cable.:D
    Mark Grants cable Rep :D
