Coaxial / Optical question
Discussion in 'Blu-ray & DVD Players & Recorders' started by [email protected], Feb 18, 2005.
  1. nic@highgroundd
    [email protected]
    Jan 10, 2005
    182
    +3
    DVD Recorder and PS2 have Optical outs - Amp. only has 1 Optical in.
    Does anyone know of a solution i.e. is there an Optical to Coaxial digital cable?
  2. John
    John
    Dec 13, 2002
    11,682
    +3,350
    Try a search for optical switch or splitter . I use a slitter with no problems
    JS
  3. John
    John
    Dec 13, 2002
    11,682
    +3,350
    or even a splitter :D
    JS
  4. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
    Hi JS, where did you get your splitter from? I got one from ebay the other day but for some reason it did not work even though the light was passing through it fine.
    Greame
  5. SamirP
    SamirP
    Apr 28, 2003
    1,317
    South Of The River
    +39
  6. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
  7. Wackojacko32
    Wackojacko32
    Jan 6, 2005
    239
    Pinxton, Derbys
    A switch would be you best bet, see link provided above. AFAIK a splitter is for driving two amps/receivers fromone source and if used the other way round the amp could confude the two signals if both are switched on at the same time.
    You asked about a optical/coaxial converter. These are available for a bit more than the switch (see www.maplin.co.uk) but it does mean you dont need to switch manually. Make sure you get the right converter, i.e optical to coaxial, and you will need and optical and a coaxial cable.
    HTH
    Wackojacko32
  8. John
    John
    Dec 13, 2002
    11,682
    +3,350
    So turn one onto stand by , I do :D
    Its a maxview one from B&Q , use it with SKY+ & Xbox .When I turn Xbox on , I put Sky+ into standby .Never had a problem yet
    Atb
    John
  9. Wackojacko32
    Wackojacko32
    Jan 6, 2005
    239
    Pinxton, Derbys
    OK in principle, but what if he wants to play on PS2 while recording on the DVDR, he'd have to unplug one of the optical cables, not ideal but only marginally more annoying than using a switch I suppose :)
    Wackojacko32
  10. John
    John
    Dec 13, 2002
    11,682
    +3,350
    My appologies , I'm used to being able to record while SKY+ in in standby ;) :D
    Atb
    JS
