Coaxial Cable from Denon 3910 to Sony STR-DB1080
Discussion in 'Cables & Switches' started by Seth Gecko, Oct 13, 2004.
  1. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
    Help!!!!!!!
    I have a Denon 3910 and Sony STR-DB1080. I have an issue which is that when connecting them together using the Digital Coaxial cable - a good quality cable (Such as a QED Cable) does not give me any sound whatsoever, but using a very generic cheap cable does.
    I recall this occuring before with another cable - I put that cable on my laserdisc player and I got sound no problem but on the DVD player (at the time) I didn't receive any sound.
    Is there any issue with the amp and DVD players using the coaxial or am I being really dense and missing something obvious ? I'd obviously rather use the decent cable over the cheaper one, but it's the only way I get sound !!
    TIA
  2. kraal
    kraal
    Aug 23, 2004
    103
    Portugal
    The coax output/input is correctly configured?
    The cable is unidirectional or bi?
    Try to measure the cable and see if it have lower Ohms. If you get high resistence, you have to see where it is broked/unsolder.
  3. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
    Doh!
    Cable is uni directional apparently and I missed the arrows!! White arrows on White coax is REALLY hard to spot!
    Thanks for the heads up - shall try and feel less dense!
  4. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    might be bad contact somewhere.
    measure it by putting the probes on both ends and try moving the cable.
    anyway i would not use that one
