Coax vs Optical
Discussion in 'Cables & Switches' started by neal666, Feb 27, 2005.
  1. neal666
    neal666
    Dec 29, 2004
    196
    +3
    Ok probably been debated here before but i going to start upgrading my interconnects and want to know which i should use where ever possible..... i know its probably going to come down to personal preference but which performs the best????
    Couple of other things ?
    How would a Optical Cable compare to the likes of a `Mark Grant` Digital Coax?
    Is there a Difference (would you notice) Between a £10 Optical Cable and a £50 Optical Cable or are you just paying for names?
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    It has been debated many times.
    I can't tell the difference between Nordost Glass and El Cheapo optical.
    Some say Coax is better for short runs and optical for longer runs. Personally I can't tell.
    I can tell the difference between some Coax and optical. Coax tends to sound a little more 'real and musical'
    Mark grants cables are very good.
    Use which ever suits you best.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,808
    Somewhere in South Yorkshire
    +6,416
    I cannot tell them apart. Whilst I'm sure there are theoretical arguments either way (and some who believe in them so much as to get all anally-retentive on the subject) the real proof is in the listening. And my listening tells me to use whichever is to hand and/or for which there is a convenient empty socket.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    Purists would argue that optical can suffer from "jitter".
    Another set of purists would argue that co-ax can suffer from the effects of a direct DC connection between the cable grounds.
    However, I agree with Nigel. No discernable difference. Use whatever you have spare. If you have to buy, buy optical, because it's cheaper. Cheap optical cables work very well.
