Coax vs Optical
Discussion in 'Cables & Switches' started by freeranger, Oct 25, 2004.
  1. freeranger
    freeranger
    Given the choice for a DVD player, which is deemed "better" - coaxial or Optical?
    The length needs to be around 3m
    thanks.
  2. dj_johnnyg
    dj_johnnyg
    Personally I can't tell the difference!
    I asked this question myself in my local hi-fi shop, and they said that coax is the better connection as the signal is kept electrical.
    For an optical output, the signal is converted from an elkectric signal into an optical one, and then back to electrical, whereas the coax signal has no conversion.
    Hope that makes sense.
    Too early on a monday
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,350
    Rainham Essex
    +2,441
    dj_johnnyg is correct in what he says about the conversions required for an optical lead, but as he also says in real life most people wont hear any difference between them.
    So the general rule is that use coax for short runs and if a long cable over say 5m is required then optical is less likely to pick up interference or loose signal over the length.
    Mark.
  4. freeranger
    freeranger
    Thanks guys, much appreciated.
  5. stuartsjg
    stuartsjg
    you should note that no "conversion" takes place in making electrical into optical or the other way round.
    Some DVD players that have both outputs have an LED wired to the same output pins on the DAC, the coax will have a resistor to make it 75ohm and absorb reflection, the LED will have a current limiting resistor to stop it blowing.
    The signals are identical.
    Optical provides electrical isolation, Electrical doesent.
    I think its best to have everything electrically connected to stop voltage diffirences occurring.
    Normally cant hear any diffirence though.
