coax to optical
Discussion in 'AV Receivers & Amplifiers' started by jspone, Jan 8, 2002.
  1. jspone
    jspone
    Dec 5, 2000
    89
    Lancs
    A mate of mine wants to connect his Alba DVD player (which only has a digital coax output) to his Yamaha amp (which only has an optical digital input).
    Is there a cable or 'magic box' which will do this?
    John
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    There is indeed a 'magic box' available at Lektropacks .
    Ain't cheap though (good stuff never is), but I have assurance first hand that it is a quality piece of hardware.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    go to www.maplin.co.uk they do a couple look in audio (category) and then Audio Switch & Cable (product) £19.99 not bad and silver.
  4. jspone
    jspone
    Dec 5, 2000
    89
    Lancs
    thanks guys
