Coax Red & Black Speaker Cables to Scart possible ?
Discussion in 'Cables & Switches' started by malibu, Aug 11, 2005.
  1. malibu
    malibu
    Jul 23, 2005
    9
    Im getting a new TV but would like to keep my Old speakers as their quiet good, Their the raw wire coax Red & Black socket type that insert into holes when Red or black plastic button is pressed down not sure on name of them, only problem is my new TV only has 2 scart inputs i think , maybe theres a phono somewhere, what type conversion cable would i need, maybe i could buy composite connecters and feed the wire into them then insert into Phono input
    Thanks Malibu .
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,804
    The Borders
    +2,470
    malibu
    If you plan on using external loudspeakers with your TV then your TV has to be fitted with a set of Loudspeaker terminals - it doesn't sound like this is the case.
    The type of loudspeaker terminals you describe are often called 'spring clip' terminals.
    If you want to use your loudspeakers with your TV you could connect one of the SCART output sockets on the TV to a suitable Stereo or Multi Channel (AV) amplifier and the loudspeakers then connect to and are driven by the amplifier - you'll turn the TV's inbuilt speakers down to zero and adjust the amplifier to your desired listening level.
    Best regards
    Joe
