Coax or Optical
Discussion in 'AV Receivers & Amplifiers' started by SCAMP, Jan 29, 2003.
  1. SCAMP
    SCAMP
    Dec 2, 2002
    35
    I have a Denon A11SR Amp.
    I have purchased a Chord Coax Digital cable to
    connect to DVD (Denon 3800) but am i better buying an optical cable?
  2. jspone
    jspone
    Dec 5, 2000
    89
    Lancs
    There are people who say coax is better and swear they can hear the difference. I'm not one of them. If coax is what you've, that's fine.
    John
  3. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Coax is fine. Not saying it's better but I wouldn't see a point in changing it unless we are talking lenght over 10m or you are picking up some radio stations (stop laughing! ;) ) with it.
  4. alextgreen
    alextgreen
    Apr 17, 2001
    547
    London
    +5
    Optical cable = DVD to Optical encoder to Optical decoder to amp circuitry
    Coaxial = DVD to Amp circuitry.
    KISS, Keep It Simple Stupid. The fewer links in your system the higher the purity of the signal.
  5. SCAMP
    SCAMP
    Dec 2, 2002
    35
    Thanks-I'll stick with my Coax cable.
  6. juboy
    juboy
    SCAMP, be sure to check back in about two days time, when someone else will have asked whether coax is better than optical, you'll probably find another bunch of responses to weigh up.
    Combine that with the huge archive of similar threads (which are accessible via the 'search' button to your top right) and you'll have days worth of info telling you that nobody really knows conclusively for your particular situation :rolleyes:
  7. jspone
    jspone
    Dec 5, 2000
    89
    Lancs
    juboy, lighten up dude. he’s new to the forums.
  8. juboy
    juboy
    jspone... apologies, maybe I was a little harsh, although it was meant in jest.
    Seems to me there's an awful lot of new members suddenly asking the same old 'designed to provoke' questions at the moment... it's hard to tell what's for real and what's not :confused:
  9. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    this happens everywhere. its something you just have to deal with. no amount of "use the search button" or "its been asked a million times before" will help, infact, it just seems to push new members away rather than encourage them to use the forums.
    A simple 1 line answer is usually all that is needed. When worded correctly, offers more information than any search button will ever provide.
  10. SCAMP
    SCAMP
    Dec 2, 2002
    35
    Thanks for the advice and support.
    I won't take anything personal and am used to
    straight talking but the repetitiveness of some questions
    Is unavoidable in a great Forum like this.
  11. jspone
    jspone
    Dec 5, 2000
    89
    Lancs
    perhaps we should have 'sticky' at the top of the forum with the top 10 recurring questions and answers
    John
  12. NicolasB
    NicolasB
    Oct 3, 2002
    6,367
    Emily's Shop
    +844
    I can't help feeling that a FAQ file that deals with questions asked frequently on the forums as opposed to merely questions asked about the forums would be a Good Thing; but then again I once attained close to legendary status as a newbie basher on the old "Black and White" discussion board on Lionhead Studios' website, so what do I know? :)
    A copy of what was probably my finest ever bit of newbie flaming may be found here.
  13. EvilMudge
    EvilMudge
    Yes, a FAQ is a good idea, possibly as a sticky, but I've not found any posts worthwhile for sticky status so far. The trouble is that people will get personal since they forked out £1000 on a co-axial interconnect only to find out that optical would have been cheaper and better for the purpose. That's what so great about having no money and a lot of education - I buy nothing unless I understand all the issues and technology involved. Unfortunately I don't tend to buy much.:(
    If people want to write good, technical but not obscure posts for a possible FAQ sticky thread, I'll happily stick them and keep the personal comments out.
