coax or anolouge with 3802+cd73t could not notice any differance
Discussion in 'Cables & Switches' started by mick23, Sep 25, 2004.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    hi all tried today denon 3802+arcam 73t ,normally use anoluge rca between cd and 3802, but tried using optical cable instead ,to be honest did not notice any differance,
    i believe if using anologue this uses the arcams internal dacs, if optical /coax the 3802s dacs,
    has anyone noticed benifits either way??
    thank you
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    On my equipment the analog connection sounds somewhat "hazy", the digital one is much clearer / more detailed. Only noticable with PCM (CD-Audio) though - and a good recording.
  3. bobbypunk
    bobbypunk
    If it isn't just your ears then it would suggests there is something limiting the improvement. Possibly the quality of the 3802's amplifiers or the speakers you are using would be possibilities. Also the quality of the cable would become more important with analogue connections.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    I owned a 3802 and always found it fairly poor for music. I was told by others on the forum that the weakest area of the AV receivers is normally the preamp stage and the best way to get an improvement is to get another integrated HiFi amp. This can be fed from the preouts of the 3802 to drive the front L&R speakers on the HiFi amp for DVD's etc and then CDP etc are plugged directly into the HiFi amp.
    I ended up with a 3802, Arcam Alpha 8r, CD73t and loved the sound for both DVD & stereo music.
    Mark.
  5. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    In my experience if you can't hear any difference then one of the components is limiting it. In this case it won't be the source so that leaves either your amp or speakers (or maybe both?).
    i.e. for me the following happened
    DV88+ (cd source) > Arcam A32 stereo amp > Quad 12L speakers
    RME 9632 soundcard (cd source) > Arcam A32 stereo amp > Quad 12L speakers
    sounded exactly the same for both of them. Latter when I upgraded to a poweamp with the above combination...
    RME 9632 soundcard (cd source) > Arcam A32 as a preamp > Halo A52 poweramp > Quad 12L
    sound far better than the DV88+ which had reached its limits.
    CaM
