coax digital audio cable - 10 meters
Discussion in 'Cables & Switches' started by cloudchaser, Sep 5, 2003.
  1. cloudchaser
    cloudchaser
    May 17, 2003
    83
    London
    +8
    Are digital coax audio cable available in 10 mt length or more? I have looked around but the longest one I saw on sale was 5 meters.
    I have a Toshiba 32ZP38 which has 2 digital inputs - a coax and a optical. I already have a Toshiba SD330E DVD connected to the digital optical input.
    I plan to connect my PC (a shuttle SN41G2) to the digital coax input on my Toshiba 32ZP38. Since my PC is in another room I need it to be approx 10 m. The PC has builtin SVideo and this is connected to the TV too.
    First I assume that my above configuration will work.
    Will there be a major loss of sound quality due to the length? Majority of the stuff I would play on the PC would be in stereo.
    Does anyone sell them in this length and approx cost. Will it be so expensive that I would be better off just using the normal phono inputs.
    Is there any other and better way to connect my stuff?
    All tips/advice appreciated.
    cheers
    cloudchaser
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    You'll be lucky to find a dedicated digital-coax in that length, but subwoofer interconnects frequently come in that kind of length and should do the job for you.
  3. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
  4. nathan_silly
    nathan_silly
    http://www.vdctrading.com/
    stock code-length- plus exc VAT. Price for one cable.
    110-272 10m 10.03
    110-273 15m 11.94
    110-274 20m 13.86
    110-275 30m 17.70
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
  6. monkeynuts
    monkeynuts
    May 28, 2002
    1,893
    East Devon
    +29
    You could give "Mark Grant" a PM sure he won't mind a plug!
    He made me a cracking 9m coaxial cable for £30 including delivery.
    Quality was excellent and price even better!
    Sam
  7. Garrett
    Garrett
    Apr 21, 2001
    39,866
    2
    167
    The best thief you’ll never see.
    +6,525
    I popped in to a local Sevenoaks and they ordered me a length The Producer to my specifications, only took a week to come in.
