Coax cable shielding falling apart? Can't terminate, conductor disintegrates
richpb7
Joined
Feb 24, 2010
Messages
7
Reaction score
Points
28
I was having some signal issues with this high pressure and noticed that the plug on my coaxial cable was very corroded. Thinking that re-terminating might help, I cut off the old plug to fit a new one - only to discover that the shielding metal is disintegrating when I touch it!
I've tried going back down the cable to try and find a fresh spot, but it seems to be the same no matter how far I go back - the secondary conductor is a dull greyish black, that literally falls apart on contact.
Anyone any bright ideas? Does the whole cable need replacing? This goes all the way up to the aerial on the roof, so if it's buggered, so am I ... :eek:
Sorry, the cable needs replaced. I'm guessing that rain got into it from the aerial over a long period.
Thought that might be it - at least my Dad did. Thanks for the help.
TV Buying Guide - Which TV Is Best For You?
Back
