Sorry for the long post in advance !!!
Hi, I'm having some issues with existing cabling which was put in my house when it was built. What I'm trying to achieve is to have Sky broadcast to all rooms with aerial sockets and be able to control them from that room.
My ideal solution was to take the source from the Sky box in the bedroom into its socket up to the loft, use this as source into 4 way booster box. This splits off to the other two bedrooms which is fine and pictures are good.
The issue I'm having is getting the 'Sky Eye' to work from these. They take power from the output of the sky box but this isn't working. I tried eliminating the booster and directly connecting the sky eye to the cable from the source (the loft end of the cable) and its stil not working. If I take an old aerial extension lead I had straight from the box this works. So it seems to me that the cabling to the loft is at fault.
Does anyone have ideas as to why this might be the case. A friend of mine is having the same problems !
