jselectrical
I am an Electrician by trade but as part of my work I add aerial points and move Co-ax points. I have recently moved a sat & co-ax point in a living room but have kept the same cabling, albeit shorter run now. When I put a new sat + co-ax plate on the end of the cables I get no signal. If I put a f type connector and joiner on the sat cable I get near full sky signal strength. Does the plate need to be something in particular? I'm using a standard Click mode sat + co-ax plate.
Any help appraciated
