Clueless And Past It. I Need Pointing In The Right Direction, Please !
pottydave
Hi All
I know this is question has been asked many times :boring:, but I don't know where to start.:confused: I have not looked into the world of computers for at least 3 or more years and I am totally out of date with everything. I am looking to spend around £300 to £400 on a gaming system. I don't need a monitor, what would be the best spec I could realisticaly buy for the money? :lease:As always any constructive advice would be very much appreciated.
Pottydave.
Xerstead
Are you looking to build yourself or buy one ready made?
pottydave
Hi Xerstead
I would prefer to buy ready made, but I do have freinds and family who could help me build one, if need be. Any thoughts ?
Pottydave.
badbob
Need to spend a bit more. For £400 can build this but still need a HD, OS. Plus what monitor do you have? If it's a low resolution LCD or small CRT bit pointless, I'd add a new monitor as well.
OcUK Value IP35 Pro Intel P35 (Socket 775) PCI-Express DDR2 Motherboard £59.99
(£70.49) £59.99
(£70.49)
Corsair 2GB DDR2 XMS2-5400C4 TwinX (2x1GB) £24.99
(£29.36) £24.99
(£29.36)
Intel Core 2 Duo E4500 "LGA775 Allendale" 2.20GHz (800FSB) - Retail £66.99
(£78.71) £66.99
(£78.71)
OcUK GeForce 8800 GT 512MB GDDR3 HDTV/DVI (PCI-Express) - Retail £93.99
(£110.44) £93.99
(£110.44)
Antec Sonata Plus 550 Quiet Midi-Tower Case - NeoPower 550W Modular PSU (Black/Silver)
EndlessWaves
You might be better off building it, a gaming machine for £400 is going to be a bit lopsided so you may have trouble finding anywhere selling one.
pottydave
(£70.49) £59.99
(£70.49)
(£29.36) £24.99
(£29.36)
(£78.71) £66.99
(£78.71)
(£110.44) £93.99
(£110.44)
Thanks for the pointers badbob and EndlessWaves..I don't have a problem with having one built. The PC I have now was built for me. Looking at badbobs spec, the motherboard seems quite cheap, is a budget one? Does it have raid on board? I am using a Gigabyte motherboard with a raid hard-drive at the moment and I have been very happy with it:). I don't know much about hardware, but is it still the case that it's best to buy components that can run at the same/comparable clock speeds? or am I getting a little mixed up? I think I would be looking for least 250 GB hard drive and for the OS, Windows XP home is what I am using now:). I have a small CRT monitor at the moment and would replace this eventually with 21" monitor or something similar. The rest of the spec looks OK to me, particularly the graphics card ? What about using an AMD Chip instead? Has anyone else got any suggestions? A top price, would be £500 to £550.
Thanks again for your help !
Pottydave
EndlessWaves
Pottydave
£40-£50 motherboards seem fine these days.
Most motherboards do seem to have SATA Raid, as it's the pro edition I would imagine that one does too.
You mean the old FSB/Memory syncing for clock speeds? I haven't heard that mentioned lately.
Intel's Core 2 chips are better than the AMD ones at the moment.
pottydave
Hi EndlessWaves
Thanks for the post. Yes, I think I will go for a Raid drive again and my comments about clock speeds, just gos to show you how long I have been out of the P.C. market. In regards to the above spec, I don't know anything about the recent chips from intel. So please forgive me, if I ask you how you rate the Intel Core 2 Duo E4500 chip in badbobs spec,? when compared to other intel chips? in terms of speed? value for money? future proofing?
Thanks again for any advice given.
Pottydave
EndlessWaves
I don't know how the E4500 compares, I've mostly been looking at the E8500/Q6600 myself.
Any dual-core isn't going to have a great deal of future proofing as the race for more cores starts to pick up pace, however within your budget I don't think you've got any choice, you could perhaps consider the base model of the Phenom tri-core?
pottydave
Hi Endless Waves
I think it might be worth holding on for a while, to see how Phenom tri-core chips pan out. As far as I understand it, these have not been out that long. I also did a little research regardingE4500 which seem to have a reasonable clock speed , but I have also been reading about the E6420 (at twice the price). The E6420 has caught my interest, with the reviews that I have read. Perhaps, if I wait a little while they might come down in price, as there is always a new must have chip just around the corner and I am in no rush. In the meantime, thanks to you and badbod, you have both certainly got me thinking about what direction to take with all this stuff.
Thanks again for all your help !
Pottydave
Thanks for your thoughts,
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
