clour flicker on graded tv??
Discussion in 'General TV Discussions Forum' started by basharat, Jan 17, 2002.
  1. basharat
    basharat
    Recently bought a 36 inch tv from electronics plc and the colour fades and comes back ever so slightly. It happens after a while and can be hard to spot. The tv is onl;y a few days old so what do u guys recommend me to do? return the tv or get it repaired it is a graded model.
  2. Kevo
    Kevo
    Aug 23, 2001
    5,412
    Manchester
    +151
    I would return it, defo.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,529
    Somewhere in South Yorkshire
    +6,000
    Were you made aware of this fault, specifically, at the time of purchase?
    If yes - you have little comeback.
    If no - you have a right to a flawless product. If you like the TV in all other respects - it has good geometry, for example, you may want to try a repair in preference to a replacement (which may have new problems). So decide - repair, replace or refund. You have a right to all.
    If you choose repair, make it clear (in writing preferably) that you do so without prejudicing your rights to a replacement or a refund if the repair proves to be impossible or unsatisfactory.
    If you choose replacement, make it clear that you do so without prejudicing your legal right to a full refund.
    Keep a copy of all correspondence and a detailed diary of all telephone conversations.
    Good luck.
  4. basharat
    basharat
    I am happy with the tv otherwise, good picture and sound etc . just this small nagging problem of colour flickering. The thing is you cant tell sometimes only if you look closely!!:mad:
  5. basharat
    basharat
    Well i think ill send it back- it is still under 7 days though, The packaging is out in the yard - all wet through will. So what will happoen then? I could still send it back under the 7 day policy thing?
