Wilf
I would be greatful if anyone could recommend a pair of closed headphones for use when video recording. Sound quality is important but the ability to cut out environment sound is a high priority. I will be using a lapel mic so I basiclly want something that gives me the best idea of what the mic is picking up without the background noise. Thought about some bose sound cancelling things but too expensive and probably not ideal for the job.
Budget £50 -100
Been looking at Phillips SPCHP890 at £50. Supposed to sound good but not sure about how "closed" they are.
Grado SR60 also but same issue
Thanks in advance
Mark
Budget £50 -100
Thanks in advance
Mark
