Closed - Arcam Software Updates etc - See Stickies
Discussion in 'Arcam Owners' Forum' started by Crustyloafer, Apr 8, 2005.
Tags:
Thread Status:
Not open for further replies.
  1. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    DVD Player Current Versions
    Arcam DVD88, DV88P & DV27: V1.81
    Arcam DV78, DV88Plus, DV89, DV27(V5) & DV27A: V5.17.0(i2.16)
    Arcam DV79 & DV29: V5.17.0(i1.6)
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Software release notes applicable to models DV88, DV88P and DV27
    Software release notes for V1.81
    • An improvement to the file handling for MP3 files has been implemented (longer file names are supported).
    • Audio dropout problem on DTS streams has now been improved.
    Software release notes for V1.79
    • The software upload mechanism has been improved so that it does not fail. On the upload disc, the files dvd8.bin and
    crc.txt are now required. Note that upgrading any previous version of software to this version should be done twice for the
    full benefit.
    • A new menu option has been added to the service menu to change the PLL setting on the progressive scan board (where
    fitted). This may help to remove some compatibility problems with certain TVs.
    Software release notes for v1.78
    • The format of the version number displayed when the player is powered-up (or brought out of standby) has changed.
    Previously:
    1.77 -- Software version
    02 -- ARCAM shipping region
    Now:
    1.79/LT37/02/02
    This is:
    Software Version/ Transport Firmware Version/ Shipping Region/ Disc Region
    This new method introduces an additional 2-second delay before the player responds to commands (due to the overhead of
    reading the Transport Firmware Version). This means that remote controls that support macros may have to be
    reprogrammed to cope with the initial delay (otherwise the remote control may start sending commands before the player is
    ready to receive them).
    • Players with LT Transports will run the drive at a slower speed (i.e., quieter) when playing CDDAs.
    Software release notes for v1.77
    • The mistake that caused the drawer to open sometimes on power-on (introduced in v1.76) has been fixed.
    • A “Closed Caption” option has been added to the “Subtitle” menu item. If selected, closed captions from the disc will be
    displayed. Closed captions will be off with all other options.
    Software release notes for v1.76
    • Pluge (below black) menu item.
    Until now, it has not been possible to perform a “pluge” test using the DV88/27. A “Below Black” menu item has been added
    (to the bottom of menu two), which has the options “Normal”, for normal viewing of material, and “Pass Pluge” for when the
    pluge test is being performed.
    • Toggle-bit in remote codes.
    The dependence on the toggle bit in our RC5 remote codes has been removed. This means that the unit should be
    controllable using non-ARCAM learning remotes.
    • “LOAD” brings the player out of standby.
    Pressing the “LOAD” button on the front panel when the player is in standby mode brings the player out of standby and opens
    the draw.
    • CD skip-back works at 1 second.
    It had been noted that the skip-back when a CD is being played did not work if pressed at exactly 1-second into a track. This
    is now fixed.
    • Single channel mono now available on analogue outputs.
    Some VCDs have a different language on the left and right channels. A menu option has been added (“Analogue output”,
    page 3) that allows the selection of the left or right channel only (as mono output). Note that this setting applies to the
    analogue output regardless of the disk type.
    • CR9000 support.
    The support for the CR9000 learning remote has changed.
    The “arrow” keys must be reprogrammed to emit “arrows”, not the commands shown on the keys (such as “stop”, “pause”),
    as previously.
    • Player must be reset after the self-test has been run.
    After the self-test has been run, the player will accept no further input until it has been reset.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Software release notes applicable to models DV78, DV88PLUS, DV89, DV27(V5) and DV27A
    Software release notes for 5.17.0 (i2.16)
    • Parental control removed (Access page of the Set-up menu).
    Software release notes for 5.13.0 (i2.15)
    • Improvement to handling of non-toggle-bit remote controllers.
    • OSD no longer lost after screen-saver cancelled.
    Software release notes for 5.8.0 (i2.14)
    • Minor Dutch spelling correction.
    Software release notes for 4.29.0 (i2.13)
    • Stereo + Sub caused attenuation in multi-channel mode under certain circumstances – now fixed.
    • Corrections to language strings.
    • Correction to power-on-resume function.
    • Zoom level shown correctly for JPEG images.
    Software release notes for 4.18.0 (i2.12)
    • Correction to support for “PL” button on CR-415 remote control.
    • Minor corrections to bass management for MLP.
    • Pro Logic “Auto” setting now works correctly with HDCD discs.
    • Front panel navigation menu item added.
    • Separate audio delay settings for PAL and NTSC now replace the original “Audio delay” menu item of the “Audio” page.
    • Player responds more quickly to the command to come out of stand-by.
    • Removal of screen corruption when switching between Setup menu and Programme menu.
    • Fixed Programme menu for DVDs.
    • Skip-back for DVDs now works as for CDs (skips to beginning of current chapter/track, not to the beginning of the
    previous chapter/track).
    • Problem of screen going blank in interlaced mode when switching between PAL/NTSC is fixed.
    • Support for DV78 RS232 control.
    Software release notes for 4.12.0 (i2.11)
    • Minor corrections for German OSD.
    • Fix for R1 “Murder by Numbers”
    • Dolby dialog normalisation and dynamic range corrected.
    • Dolby down-mix type corrected (broken since 3.9.0).
    • Fixed DTS/MLP redirected LFE causing distortion.
    • Fixed DTS no LFE redirection to sub.
    • Random + Programme for CDs now works correctly.
    • Improved handling of CDs with a data track.
    • Adjustments to string display of audio type (underlying code change).
    • Full bass management for multi-channel audio.
    • De-emphasis for CDs fixed.
    NOTE: bookmarks from software versions earlier than this will be erased if this software (or later) is installed.
    Software release notes for 4.0.0 (i2.9)
    • Stereo+Sub now works for MLP streams.
    Software release notes for 3.9.0 (i2.8)
    • Fix for Japanese “Beauty and the Beast” game DVD.
    • Minor tweaks to MP3/CDDA interface (programme menu fixed for MP3, CDs with data tracks are handled better).
    • Improvements to bass management code.
    • DTS decoding enabled for 6-channel players.
    • Minor fix for OSD when the OSD is disabled.
    • Minor spelling corrections for French and German OSD.
    • Picture CD works correctly on 6-channel players.
    • 192KHz output level corrected.
    Software release notes for 3.6.0 (i2.7)
    (This software is for 6-channel players only)
    • First production release for DV89/DV27A.
    Software release notes for 3.2.0 (i2.6)
    (This software is a prototype release only.)
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Software release notes applicable to models DV29 and DV79
    Software release notes for 5.17.0 (i1.6)
    Software release notes for 5.13.0 (i1.5)
    • Improvement to reliability when connected to HDMI device but HDMI not in use.
    • Improvements to remote control performance.
    Software release notes for 5.10.0 (i1.4)
    • Image positioning over HDMI corrected (offset by 4 pixels in 5.8.0).
    • Re-enable operation with broken Pioneer PDP504 plasma screens (broken in 5.8.0).
    Software release notes for 5.8.0 (i1.3)
    • Modification to the code to enable operation with broken Sim2 projectors.
    • Analogue video output fine-tune implemented in Service menu.
    • Minor changes to information frames sent over HDMI link.
    • Improvement to analogue video performance when the both the HDMI and analogue outputs are connected to the same
    device. (The “jerkiness” is fixed.)
    • Improvement to the OSD text colour in interlaced mode.
    Software release notes for 5.2.0 (i1.2)
    • Modification to the code to enable operation with broken Pioneer PDP504 screens.
    Software release notes for 5.1.0 (i1.1)
    • Correction to the “Audio Info Frame” transmitted across the HDMI link – indicates the audio format correctly.
    • When switching from HDMI with YUV output to DVI, the colour space is set correctly to RGB.
    • Aspect ratio signalling across HDMI link corrected.
    • “SPD Info Frame” across HDMI link implemented.
    • The YUV output on the HDMI link has been changed from YUV444 to YUV422. This allows below-black testing.
  5. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    AV Receiver Current Versions
    AVR300: V3.16
    AVR250: V3.16
  6. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    AVR SOFTWARE RELEASE NOTES
    For V2.90
    RS232 Command problem:
    1.DD EX command response information when DD 2.0 source input.
    2.Cannot select the DD MONO mode from DD Stereo mode by RS232 command (on DD
    5.1 source input).
    For V2.91
    RS232 Command
    a. Send “open main menu” command after sending “open Setup menu”, no response.
    b. Close setup menu should cause the "Save setting" is open.
    c. The effect modes do not show up on the OSD when being changed using, the RS232
    commands.
    d. No response sometimes, when send Left or Right Command.
    1. Tuner FM MUTE/FM MONO status isn't stored when power off.
    2. If Zone1 channel = Tuner and Zone2 channel =Zone2 Tuner, FP is in zone2 mode, FM
    MUTE/FM MONO key shouldn't be changeable.
    3. Updated Zone 2 standby status from ARCAM: The status of Zone 2 is remembered
    when the unit is powered off/on, but the video signal still comes on.
    For V2.92
    1. When a Zone 2 volume operation happens the VFD reads 'Z SAT 31dB', can it be
    changed to read 'Z2 SAT 31dB' ? This is the same for the AVR300 also and will need
    changing as well.
    2. Menu'.
    3. The power up from source key press feature. It works from the front panel PVR button
    but not from the remote control when you use the AUX key
    4. Store Zone2 Standby status when Main on/Off operation.
    5. Fixed the bug:If Zone2 volume value > Zone2 max on value, it will restore Zone2 Volume
    value when Main on/off process.
    For V2.93
    1. System Audio Mute during DSP Update processing
    2. Power off/on, Remote setting can't be saved. (RC5 16-19)
    For V2.94
    1. Store Zone2 standby status. Updated Z1 & Z2 standby operation, status by IR control
    (Please refer to file “stanby_status_testing.pdf”)
    For V2.95
    1. Received RC5 code(code=47\48) from Z1 IR will On/off Zone2 mode.
    Before:The function of these two remote code is same as the function of FP Zone2 Key.
    Now:Only Z1 IR can receive,to cause zone2 standby off or standby on.
    2. Updated the bug of RC5 code(code=124\123) standby On\Off:
    Before:If received it from Z2 remote, they cause Zone1 and Zone2 all into standby on or
    off.
    Now:Received it from Z2 IR will only on/off Z2 mode.
    3. RC5 code(code=119\120) Mute\Unmute bug:
    Before:If Zone 2 remote receive,They cause Zone1 into mute or unmute.
    Now:
    a)Received it from Z1 IR and current mode is Z1 display,it mute only Z1 mode.
    b)Received it from Z1 IR and current mode is Z2 display,it mute only Z2 mode.
    c)Received it from Z2 IR,it will mute only Z2 mode.
    Note: Item 1 to 3 can be refered as below:
    Three IR code receiver: FP, Z1 IR, Z2 IR. FP should be the same as Z1 IR.
    All RC5 codes with system code 16 should also exist with system code 19.
    Code 123/124/12: on/off zone 1 if using IR receivers-FP/ zone 1, on/off zone 2 if using zone
    2 IR.
    Code 47/48: on/off zone 2, when using FP, Zone1 IR IN. No response for Zone 2 IR.
    1. Z1 system code = 19, Z2 system code = 19
    FP/Z1 IR should respond to code 19 for zone 1 operation
    Z2 IR should respond to code 19 for zone 2 operation
    No respond for code 16 for any receivers
    2. Z1 system code = 19, Z2 system code = 16
    FP/Z1 IR should respond to code 19 for zone 1 operation(including 47/48 with code 19 to
    turn on/off zone 2), and no response for zone 2 operation.
    Z2 IR should respond to code 16 for zone 2 operation(including 123/124/12 with code 16 to
    on/off zone 2, no response for 47/48 with system code 16/19).
    3. Z1 system code = 16, Z2 system code = 19
    FP/Z1 IR should respond to code 16 for zone 1 operation(including 47/48 with code 16 to
    turn on/off zone 2).
    and FP/Z1 IR respond to code 19 for zone 2 operation.
    Z2 IR should respond to 19 only(including 123/124/12 with code 19 to on/off zone2)
    4. Z1 system code = 16, Z2 system code = 16
    no response for code 19.
    Z2 IR should respond to code 16 for zone 2 operation(including 123/124/12 with code 16to
    on/off zone2).
    For V2.96
    RS232 command -Close setup menu should go to the "Save setting" .
    For V2.99
    1.Effect mode does not show up on the OSD after being selected by RS232 on muting
    mode.
    2. When the input of the unit is set to DVD-A and the unit is put into standby, when the unit
    is turned back on again the trigger out voltage goes up to 12V (as it should) but once the
    unit has initialised it drops down to 3V.
    For V3.00
    1.Surround Mode and stereo effect mode selection via remote control bug now fixed.
    For V3.01
    1. A New RC5 code (System code 16, command code 84) added to access the setup menu.
    This replicates holding the CR80 remote menu key down to access the set up menu.
    (This also works with system c ode 19 if the system code has been changed in the
    engineering menu).
    For V3.06
    1. A separate lip-sync setting for every source. So for example if you
    are on DVD and set the lip-sync delay to 50mS to correct the DVD player,
    you can also have a separate lip-sync delay for the satellite input of for
    example 90mS. This is because sources often need different delays to be
    corrected.
    2. Centre channel redirection. With a Digital input signal (Multichannel Bitstream) applied
    and the centre speaker set to not present in the speaker setup menu. If the PLIIx Movie or
    Music mode is selected the centre channel audio is not redirected to the front Left and Right
    speakers as it should be.
    For V3.08
    1, Fixes the wrong input information being shown on the OSD when selecting inputs.
    2, Stops the FX button being used when 'Main Screen Menu' and 'Setup Menu' are
    displayed.
    V3.14
    Software difference list:
    1.The OSD will display "Not Cnt" on zone2 Source menu of the main screen 3 after unit
    power on.
    2.AUX IR command is sent twice on remote, this will only affect when change the setting of
    Access of Zone 2.
    3.The "SR Treble" can not be selected when SBL/SBR is none.
    4.VFD display info "EX Settings" change to "EX Set".
    5.OSD display Info "DTS Lfe" change to "DTS LFE".
    6.The string "Sub Woofer" on VFD/OSD is changed to "Subwoofer".
    7.Volume up or Volume down or volume knob, after pressing "Mode" or "Effect" key,
    sometimes Volume VFD/OSD is not shown.
    8.The VFD text "Sub Woof Set" is changed to "Woofer Set" when on Subw oofer menu
    operation.
    9.Update the Lip Sync display info on the VFD when adjusting Lip sync value.
    For V3.16
    1, AUX (PVR) can't be select from the Zone2 IR input.
  7. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Arcam FMJ AV8 Current Version: Version 3
  8. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    AV8 Software Version 3 Addendum
    There have been several software enhancements made to the AV8 in addition to the functionality described within the user manual. These are described in this addendum.
    SCART CONTROL
    BASIC MENU 1 – GENERAL SETTINGS
    The setting in Main Menu 1 of the Video Type (aspect ratio) which controls the output on the Video Trigger outputs on the rear panel can be set for each input. In earlier versions of software this setting was global and applied to all selected sources. It is now possible to set individual settings for each source.
    ADDITION OF DOLBY DIGITAL SURROUND EX
    Dolby Digital Surround EX mode has been added. This provides rear channel extraction for surround back speakers. This is selected using the mode button on the front panel or remote whilst the unit is decoding a Dolby Digital stream.
    Note that if THX Surr. EX control is set to ‘Auto’ in Basic Menu 6 – THX Settings, the presence of EX flags in the incoming stream will cause the unit to switch to THX Surround EX (assuming you have surround back speakers). If you do not want this to happen, set the control to ‘Manual’.
    INPUT NAME
    ADVANCED MENU 6
    The displayed input name can be given a new name, up to a maximum of 13 characters. This is set in Advanced Menu 6 – Input Name.
    All possible sources are shown on entering the menu. To rename an input, move the highlight bar to the name you wish to change: you are prompted to ‘Press OK To Edit Name’. Pressing OK causes a flashing cursor to appear on the first character.
    Now use UP/DOWN to change the character, and LEFT/RIGHT on the remote (or the Control knob) to move the position of the cursor. When you have finished entering the name, press OK to store the new name.
    If at any point of the name editing process you wish to exit the ‘edit mode’, pressing MENU returns the name of the selected input to its last saved name.
    Note that input names are not stored as part of the presets. Therefore if the input names are changed, these names apply irrespective of the preset recalled.
    PRESET SAVING OPTIONS
    In the Save Settings menu, pressing OK when “Press OK to save” is shown takes you to a further menu: the Preset Saving Option menu. This menu gives you the option to change which settings are saved for each preset.
    The following options are available:
    Volume Setting
    If ‘Yes’ is selected, the volume for Zone 1 is recalled when selecting this preset.
    Input Source
    If ‘Yes’ is selected, the saved audio and video input sources are recalled when this preset is recalled.
    Src Specific Items
    Each Source has its own value for each of the following settings. The preset stores all of these settings for each source.
    If ‘Yes’ is selected, the following settings are saved for this preset:
     Decode Mode
     Downmix Setting
     THX Setting
     Effect Mode
    Main Menu Screen 1
     Video Type
     Bass
     Treble
    Main Menu Screen 2
     Lip Sync
    Advanced Menu 5 – Input Trims
     Analogue Input Gain settings for all sources.
    ZONE 2 SETTINGS
    If ‘Yes’ is selected, the following items are saved:
     Zone 2 Audio Source
     Zone 2 Video Source
    In Advanced Menu 4 – Zone2
     Zone 2 Max Vol
     Zone 2 Fix Vol
     Zone 2 Max On Vol
     Zone 2 OSD
     Zone 2 Access
    3 RECORD LOOP SETTINGS
    Main Menu Screen 2
     Record to Tape
     Record to VCR
    Once you have selected what settings you wish to save, highlight the ‘SAVE’ text and press OK.
    After saving, you are returned to the ‘Save Settings’ Menu. To leave the menu without saving any changes, highlighting ‘DO NOT SAVE’ and pres OK, or press the MENU button.
    RS232 INTERFACE
    To allow control of the extra functionality, the RS232 interface has the following additions:
    QUERIES
    ?THX can now return the value ‘5’ to indicate Dolby Digital Surround EX.
    GENERAL OPERATIONS
    THXy: THX Mode selection, where y can now take the value 5 to switch the unit to Dolby Digital Surround EX (assuming that this is allowed by the current configuration).
    ADVANCED INPUT NAME
    INPNin where i is the input number (2 = AUX, 3 = CD, 4 = TUNER, 5 = DVD, 6 = SAT, 7 = AV, 8 = MULTICHANNEL, 9 = TAPE, A = VCR) andn is the new input name, with a maximum of 13 characters.
    SAVE SETTINGS
    SAVyp0p1p2p3p4 where y = 0 … 5(0 = Current Preset, 1 = Preset 1, 2 = Preset 2, 3 = Preset 3, 4 = Preset 4, 5 = Preset 5)p0=1 saves volume, p0=0 doesn’t save volume p1=1 saves Input source, p1=0 doesn’t save Input source p2=1 saves source specific items, p2=0 doesn’t save source specific items p3=1 saves Zone 2 settings, p3=0 doesn’t save Zone 2 settings p4=1 saves Record loop settings, p4=0 doesn’t save Record loop settings.
    Omitting p0 to p4 results in only the source specific items being saved, which is the default setting.
    CRESTRON CONTROLLER
    Please note that programming support for the AV8 is available from Crestron UK and Crestron Electronics, Inc.
    View Crestron’s website (www.crestron.co.uk) for details.
    Note: In issues 2.0 to 2.4 of the AV8 software, the 12V trigger outputs for zone 1 and zone 2 were reversed. This has been corrected from issue 2.5.
    If you are using trigger outputs and are upgrading from a software version previous to 2.5, you will need to reverse the connections.
  9. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    Thanks Crustyloafer!
    This deserves a sticky!
    One more thing, it would be nice to state how can owners identify witch firmware version their players have.
  10. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    To identify the current version of firmware on your DVD player it is displayed briefly upon powering up at the top of the screen, alternatively it is easier to enter the Engineers menu and check the version there. To do this follow these steps:
    1. Press 'Setup'
    2. Press '4792'
    3. Select 'Version' and press 'Ok'
    This procedure applies to all of the most recent version of player but i'm not sure about the original DV88 and DV27.
  11. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    To identify the current version of firmware and DSP on the AVR250 and AVR300 press 'DVD' and 'SAT' together on the front panel.
  12. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I should also note that anyone planning to update the firmware on the AVR250 or AVR300 that does not have DSP version 1.12 should apply this before applying any other updates.
  13. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    To identify the current firmware version on the Arcam FMJ AV8 you press and hold the 'CD', 'DVD' and OK' buttons together.
  14. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Arcam Solo Current Version
    File Name: l968sw_1_4.a37
    Release Notes: None
    To identifiy current firmware version press the follwing buttons in order keeping the previous ones held down:
    'Mute', 'Volume -' and 'Volume +'
    Once the dispay changes you can release these buttons and use the 'Source +' and 'Source -' buttons to scroll through the display and find the firmware version.
  15. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    I'll keep this thread clean so that Crustyloafer or any other member that has Arcam Intel can continue to provide useful infomation to Arcam costumers.
    Please do not reply to this thread with questions or comments. It will benefit all of us. :lease:
    (P.M. me if necessary)
    Thanks,
    Mutley - Moderator
  16. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    New Firmware Version for AVR300/AVR250/AVP700: Version 3.25
    Release Notes:
    V3.16 to 3.20
    1.All PVR to AUX on all OSD(AVP700)
    2.Default max on volume to 70dB(AVP700 & AVP701)
    3.The volume Gain have changed to 6dB,12dB,18dB in this version.
    (AVP700/701)
    4.Save the Tune/Preset flag of Tuner Source after power down.
    (AVR300,AVR250,AVP700/701)
    5.Fixed the below bug:
    The unit have none signal on output when it power on with direct and
    headphone on(AVR300,AVR250,AVP700/701).
    6.Mute the HDMI output for 700ms when switching different HDMI source input
    (AVP700/701).
    7.Using a main-MCU pin(P2^2) to mute all the channel on AVP700/701
    model(AVP700/701).
    8.Remove all the operation of "using 6+7 speaker for zone2" from AVP700
    model software(AVP700/701).
    9.USA version update info(AVP701) including
    Change the button "Zone2" to "Mute" on the front panel.
    Change the button "Mute" to "Standby" on the front panel
    V3.20 to 3.25
    1.Updated the output level on speaker noise test mode(AVP700/AVP701).
    2.The decoding mode "PLII Music" is available for Dolby Digital 2.0
    source input.
    3.FM Mono is not available in Tuner Preset mode.
  17. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    New firmware for Arcam DVD Players: Version 5.25
    1. DVD order programming menu fixed
    2. Test noise fixed - previously broken if fewer than 5.1 speakers were present
    3. Improvements to remote control performance
    1. DVD title/chapter programming menu fixed
    2. DV29 HDMI channel swap corrected
    3. DV29 'HDMI multi channel' audio menu item added
    4. HDMI muting pattern changed
    5. HDMI communication (DVD player to sink) improved (made more reliable)
    6. DV29 ACP copy-protection over HDMI implemented
    7. Widescreen signalling over HDMI implemented correctly
    8. CD playback no longer stops when an HDMI-connected device is switch on/off
    9. PAL interlaced (576i) performance over HDMI improved
    10. Test noise fixed - previously broken if fewer then 5.1 speakers were present.
  18. Hifi addict
    Hifi addict
    also added to the AVR300/250/700 3.25 sw version is the tuner pre-set bug fixed.
    The machine now boots in "P"reset mode and pushing the next/previous on the AVR300 or on the remote in "aux"mode will let the tunerchannel move up/down
  19. Hifi addict
    Hifi addict
    btw, I just noticed that the AVP700 is on sw version 3.27
    Not sure what the differences are compared to the 3.25
  20. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Software Version is now at 3.28 for the AVR300, AVR250 and AVP700. Please find atached a copy of the release notes.
  21. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Arcam FMJ AV8 Version 4 Software now released. Please attached file for ammendments.
  22. jont
    jont
    Apr 8, 2002
    4,251
    near Aylesbury
    +551
  23. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    New Arcam Solo firmware available. See attached file for ammendments.
    EDIT: Attachment removed as it needed to be attached to a newer post.
  24. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
  25. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    New firmware available for Arcam DVD players. This firmware update primarily affects the DV79 and DV29. See attached release notes for ammendments.
  26. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Arcam FMJ AV8/9 Version 5.0 Software now released. Please see below for ammendments.
    Issue 5.0 12/12/05
    1. RS232. Unit locks if sending volume larger than max volume.
    2. Mute. Unit comes on at 0 volume after switching it off in mute.
  27. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    New Arcam Solo firmware available. Now version 2.1 with iPod control using the new R-Lead and R-Dock. See attached file for ammendments.
  28. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Arcam AVR250/300 and AVP700 Firmware version 3.36 now available. Please see attached PDF for ammendments.
  29. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Arcam Solo Firmware version 2.2 now available. Please see attached release notes for ammendments.
  30. thudspud
    thudspud
    Mar 28, 2002
    2,399
    Sheffield
    +130
    Hello Crustyloafer
    EDIT: ALL SORTED, THANKS.
    I was wondering if you are able to supply me with the latest firmware for an Arcam DV27A that I am having a few issues with, I bought it second hand off the forum. I have never bought anything Arcam from my local dealer so don't know if they would help me and the dealer I bought my other Arcam gear from is down in London and has now closed down.
    Chris
Thread Status:
