close to buying pw7
Discussion in 'Plasma TVs Forum' started by Procter, Mar 7, 2005.
  1. Procter
    Procter
    Oct 29, 2004
    32
    Im looking at buying the pw7 42 " from 123electricals
    the actual package is
    th42pw7b £1293.94 (inc free delivery)
    this comes with 1 year manufacturer warranty(is that enough)
    i was also going to pay the extra £200 for the stand ( could have the wall bracket instead) and the tuner.
    the reason for my post is i need to make sure that this tv is very capable of watching football ,watching dvds and playing my ps2 on it , i will also be connecting it by ntl digital (soon sky+)
    do i need to buy the tuner box or is there a better cheap way
    finally is this tv futureproof?
    I need a very urgent answer (as i think the missis might change her mind about letting me use her car fund he he :thumbsup: )
    Thanks for all your help
  2. pioneerman
    pioneerman
    Mar 25, 2004
    2,599
    71
    surrey
    +74
    the extra £200 for the tuner and bracket is a good price and the cheapest. not the best for picture quality the tuner ,but seems like a good deal.as far as the pw7 is concerned you cant go wrong there, one of the best.
  3. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    you will probably want to upgrade from the tuner quite quickly and buy terminal boards for direct connection of your kit to the panel and if you have an amp you can route via that to reduce connections. It is not future proof if you mean is is sky hdtv but personally i don't see that as an issue as it will be years before the content will be worth worrying about. It is a very good screen but ideally you should try and see one if you can.......even though i didn't and am very happy with it.
  4. c4lln
    c4lln
    the tuner box is 200 pounds more, you get the screen, scart and stand for £1293.94. personally i couldnt wait anymore, mine is being delivered on saturday. :clap:
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    not futureproof but incredible VFM and are you sure they have stock?
  6. Procter
    Procter
    Oct 29, 2004
    32
    so can i just connect a multi switch scart socket up to the free scart board that you get ? then later on in the year i could add the various other component boards?
  7. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
