Close Encounters Region1
Discussion in 'Movie Forum' started by eros, May 20, 2003.
  1. eros
    eros
    I've just been on DVD Boxoffice site and they have 2 versions of this movie double and single disk. My question is; Is the text correct when it says the single disk version has 16:9 image and the double is 2.35:1 image? If so whats the logic behind this?
  2. Rambo John J
    Rambo John J
    Aug 11, 2000
    4,554
    Hanoi Hilton
    +1,682
    the 16:9 just means it's anamorphic.
    Both the single and 2 disc versions are anamorphic 2.35:1. Like they should be.
    It's about time someone introduced a standard when it comes to site info regarding DVD specs. Depending on who uploads the info you can have different interpretations of what the specs actually are.:nono:
    The fools:rolleyes:
