cloning a system HDD
D20PAX
hi guys.
i have my htpc running and have spent a long time getting everything perfect( all my setting, codec, files) but i would like to put a second media pc upstairs.
if i build it with identical componants could i do a HDD clone and make both systems the same in a single step.
i understand that xp will need a extra licence key and re-activating but this is no problem.
can it be done i rely dont fancy spending all that time again tweaking and setting it all up again.
thanks in advance
I would definately recommend using Acronis.
Please note that link only provide a registration key...
I would recommend you backup to a FAT32 partition (or external hard drive) as Acronis can sometimes have dificulty reading from an NTFS drive when restoring due to permissions.
Easiest way to image is to just create a bootable disc, boot from the disc and launch Acronis. et Voila
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
