Clock on Panny EH60D hasn't automatically changed
Discussion in 'Blu-ray & DVD Players & Recorders' started by gobstopper, Mar 26, 2006.
  1. gobstopper
    gobstopper
    Dec 13, 2004
    552
    28
    +69
    Anyone else noticed that the clock on their Panny EH60D is still in GMT.
    I checked my unit last night before bed and noticed that there was an "Auto" setting in the clock screen. This was on, so I left it so and went to bed.
    Today I have checked the clock on a few occasions and it is still an hour out.
    Is there something else I should have done?...
  2. jaigee
    jaigee
    Jan 20, 2005
    189
    +20
    No, the same thing happened last October, on the change back to GMT, they eventually changed during the day.
  3. pappyon
    pappyon
    I complained about this last October, and everybody else said there machine had changed.
    I have two drmeh60s and they hadn't changed this morning but eventually they did. It seems they do it in their own time if left alone.
    Having said that you can change the clock manually if you wish. Instructions are in the manual
  4. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    It gets the time from the TV stations.
    You must have the aerial connected before switchon and the machine must be on and tuned in. It should soon aquire the correct time. Leave it on BBC1.
  5. laser
    laser
    Aug 1, 2004
    1,021
    Hartlepool
    +54
    Well I set my DMR-EH60D time to record next weeks TV programmes yesterday afternoon.
    Low and behold when I checked the time on the recorder this morning it hadn't forwarded one hour but all my timer recordings for next week had moved back one hour i.e. Planet Earth 21:00 to 22:00 had become 20:00 to 21:00 and Mojo was highlighted in the EPG with the timer symbol rather than Planet Earth.
    I would have put it down to user error if I'd only set the timer for one programme but it occured on all seven time recordings. :(
  6. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,156
    +7,097
  7. DRAMBO
    DRAMBO
    Feb 15, 2005
    157
    West Yorkshire
    +5
    The time on my ES20D changed okay. Did you have your recorder on standby overnight, the time is changed when EPG is updated.
  8. LCDC
    LCDC
    Jul 5, 2004
    95
    Lancs.
    A similar thing happened on my EH60D, although the clock actually had gone forward by itself an hour today (unlike last October), but the timer recordings I'd set on Saturday for "Planet of the Apes" (18:00 to 19:00), and "Planet Earth" (21:00 to 22:00) both recorded an hour early when I came to check the programmes tonight :(. The recordings both had the correct descriptions on them, but they'd both recorded an hour too early. What should have been "Planet of the Apes" was actually an hours recording of a black screen :eek:, as ITV4 doesn't go on the air until 18:00. This was extremely annoying, as this series isn't repeated during the week :thumbsdow. Thanks for nothing Panasonic :lesson:.
  9. DaveG_UK
    DaveG_UK
    Mar 26, 2006
    69
    Hull
    FWIW, I have a Panasonic DMRE75, and find the daylight saving adjustment to be a little sluggish too.
    What I have found works is to go into the Time and Date Settings and turn the automatic clock adjustment off, then press return, then turn the automatic clock adjustment back on. This seems to force the unit into checking the current time and thus it picks up on the hour change.
    Hope this helps.
  10. gobstopper
    gobstopper
    Dec 13, 2004
    552
    28
    +69
    UPDATE
    I double-checked the manual which indicated that the machine needed to be in standby mode for the automatic clock update to work.
    So this morning I put the unit into standby mode and the time updated itself automatically within a few minutes.
