Quantcast
Clippers for hair
wiz
Why, washing yer clippers? :D
Flashy
Done mine. It’s not perfect. It’s not necessarily good. And I’m certainly not putting up a picture! But it is serviceable, certainly at the moment.
Clippers were £12.99 so I’ve paid more for worse haircuts. Even if they’re only used once (optimistic..?) they’ve paid for themselves.
As much as I don’t relish the whole barber experience I’ll go back to it once this is over because I’m happy to pay someone else to do it properly and, perhaps more so, to clear up the mess.
How wrong can a number 1 all over get? :D
Flashy
I tried to get clever. It’s an 8 on top, blended in to a 1 back and sides. I use the word ‘blended’ in its loosest-possible sense. :)
And there’s a bit of a tufty bit around the crowns (I have two...) that was ungettable somehow.
Venomx999
Been using the Remington quick cuts for. Few weeks now. Does the job of a blade 2 all over
GuitarGuy
Now the barbers are shut I’m looking for some good hair clippers. I usually have a skin fade so will have to forget about that for now. So I want some clippers that I can use on my hair to do a 2 or a 3 all over?
Just my personal opinion fwiw I did my own hair for the same reason and with the same logic, 1/10 would not recommend
IronGiant
Would not recommend what? :confused:
Welcome back by the way :)
^^^ DIYing it I think ... though he may have not used a DIY clipper like the Phillips rotary head one, or the Remington; although I was also pretty good with a normal clipper on myself
I couldn’t do it with normal clippers myself either. But the Remington quickcut is great and easy. And yes the Philips looks similar.
Inked
I can imagine it being difficult to do it yourself with normal clippers if going for anything other than a zero all over.
But it’s incredibly easy if taking it all the way down. The only issue I ever had was that it didn’t cut close enough so I switched to using a beard trimmer instead (before taking to wet shaving)
rousetafarian
Prepare to flame me, I’ve got a very good Philips beard trimmer from 1mm to 15mm, can I give myself a grade 3 buzz cut?
Sloppy Bob
No reason why not. It might not be as good as hair clippers but it will still work.
I used a Panasonic beard trimmer that had good reviews for hair as well and gave myself a 2 all over.
Similar threads
Latest News
Samsung unveils Terrace weatherproof 4K QLED TV for outdoor viewing
  • By Andy Bassett
  • Published
AVForums Podcast: 24th May 2020
  • By Phil Hinton
  • Published
Sky HDR launch rumoured for 27th of May
  • By Andy Bassett
  • Published
Sony 2020 8K LED and 48-inch OLED TV prices leaked
  • By Andy Bassett
  • Published
iFi launches iPhono3 Black Label phono stage
  • By Andy Bassett
  • Published
