clip reverse in pinnacle 8
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by chickenslippers, Mar 25, 2003.
  1. chickenslippers
    chickenslippers
    once you have fed your camcorder into pinnacle 8 and it has sorted your clips is there a way to get the clip to play in reverse. I can get the clip to play slower via clip properties but not reverse.
  2. JefUK
    JefUK
    Mar 31, 2002
    444
    28
    +53
    To play video in reverse with Studio 8 you need HFX Plus (I think), or Pro.
    With this you can reverse video and make transitions and special effects.
