M
mikegp
When I capture from my Sony Camcorder each shot is numbered in the Media Window starting filename.01 upwards. Above filename.99 it automatically uses three digits eg filename.100, filename.101 and upwards. The earlier files then become entangled when saved and reloaded, ie filename.10 is between filename.99 and filename.100. Does anyone know how to change the default numbering system to always use three digits ie filename.001, filename.002 etc. so that all the files remain in the correct sequence? This would make it easier to edit to the Timeline.
