Clickshare bad quailty
qwerty3009
Hello,
Having a problem with a Barco Clickshare (CSE-200). The Clickshare is connected to a Cisco SX80 and the SX80 goes to the screen. The screen is a new 98" Phillips screen.
The picture looks bad. There is to much light in the picture and you can not see thin small lines. Only a problem when someone is presenting a big high quality picture with a lot of lines, example map with hight curves.
If I connect the Barco directly to the screen it looks good.
Have a equal setup on another location it looks good there.
Any ideas?
Tried with a CSE-200+ and same thing there.
Any settings on the SX80?
