I have been having problems with my TV LE46B750U1W which has been making that classical clicking noise. It has been turning on and off and recently not turned on at all. I changed the faulty power board 2 months ago which solved the issue. Now the problem has came back. I had a look at the "new" power board and there doesn't seem to be any bulbous caps. I then disconnected that massive white cable that connects the PSU to the motherboard and noticed that 3 pins has been burnt. I took a picture of it and reassembled the TV - turned it on and it started working again after a few clicks. A few days ago, it wouldn't even turn on - just had the constant red standby light without even hearing the clicks. The cable itself has the number DZ090301H imprinted but I cannot seem to find it online.
Anyone have any ideas where I can a replacement cable ?
If I cannot "fix" this TV, I would be rather disappointed as it functions pefectly well and it would really be a shame to scap it just from 1 minor problem.
If I were to get a replacement TV, my budget will be probably anything under £1000 - any suggestion ?
