shooeyd
I bought a used Clearco HD9000 only to get it home and find that the image was dull and a patch appeared. Turns out its probably the lens as when I opened it up I could see some sort of thin black len on the front lens.
The bulb has some bubbling/misting also but I doubt thats the root of the problem.
So two queries:
1 - I removed the bulb but am not sure if it needs to go back in a particular direction (e.g. positive/negative?
2 - Can the front lens be replaced??
So two queries:
