Clear Speakers
Discussion in 'Home Cinema Speakers' started by garlik_bread, Dec 11, 2008.
  1. garlik_bread
    garlik_bread
    Nov 15, 2007
    465
    Cardiff
    +14
    So i was watching the IT Crowd yesterday, and in thebackground i noticed a cool looking clear/transparent speaker. Does anyone know what they are?
    Heres a screencap:
    [​IMG]
  2. Scott_Mac
    Scott_Mac
    Jul 4, 2005
    6,022
    2
    2
    Bromsgrove
    +592
    I know of a couple of manufacturers that make clear speakers... but they don't look like them...
    They look quite 'home made' if i'm honest!
  3. Subliminal Aura
    Subliminal Aura
    Jun 2, 2007
    1,509
    Enfield, London
    +93
    :rotfl: at myself for landing here as I'm watching the same episode and decided that I too wanted one of those.
    Yes that one definitely looks hand made but I'm sure I've seen some high end speakers produced a few years back in similar housing.
    Any one know who made them ?
  4. PSM1
    PSM1
    Dec 20, 2008
    26,248
    +5,410
    I know Celestion used to make a clear speaker. Used to be able to get them in Richer Sounds.
  5. BlueWizard
    BlueWizard
    Jun 19, 2007
    21,570
    +4,025
    These are open baffle speakers, usually referred to as OB. Meaning that they are just a front, no sides or back, hence open baffle.
    Likely they are home made, and likely, since they are sitting in the corner, the corner is actually part of the speakers. In a sense, using that corner as apart of the speakers, we have a rear loaded horn.
    Unfortunately, the image isn't clear enough to identify any of the components.
    Steve/bluewizard
  6. ARNOLD AKIEN
    ARNOLD AKIEN
    Aug 22, 2007
    2,617
    103
    SUNDERLAND
    +347
    There are certainly some peculiarly Clear Speakers that might fulfill any craving for transparent oddness that you might have :D how abut these ...
    LinkNotes: Transparent Speakers
    " From a cool chic factor point of view these speakers are the absolute business, you’ll need a fair amount of space to accommodate them to full affect, but if you can afford them I don’t think space is going to be a problem. The full set of 2 1.65 metres floor standing speakers, 2 required sub base units and amplifier have a street price of just under 15,000 sterling (that’s about 26,500 USD) which though costing more than a decent car will give your next party something talk about as well as listen to. "
    Or there's these ...
    Korean startup to produce thin, transparent speakers - Engadget
    Then theres This ...
    Plug & Play - Wireless Speaker System by Per Brickstad » Yanko Design
    Which comes close enough to " a cool looking clear/transparent speaker " to be a variation of the same design
    If I were to choose a really weird Glass Speaker then this would do nicely ....
    " Arabesque glass speaker redefines transparent sound "
    DVICE: Arabesque glass speaker redefines transparent sound
    and here it appears in Public just in case you needed a Shopping Opportunity after visiting The Casinos at Vegas ...
    SoundStage! Network Las Vegas 2009 Special Show Site
    " The speaker's concept is the vision of Crystal Cable president Gabi van der Kley. Her mandate for all Crystal Cable products is that they be technically proficient, musically satisfying, and visually pleasing. "
    And Very, Very Expensive I dare say. :devil:
    Arnold.
