Cleans lens with Scotch tape?
Discussion in 'Photography Forums' started by RMbA, Mar 4, 2005.
  1. RMbA
    RMbA
    Recently came across the suggestion to use Scotch tape to remove all kinds of foreign matter from lenses and filters. Tried it and found the results to be excellent--fingerprints and dust removed perfectly. But a professional protographer told me that the tape might leave residue and could possibly remove the lens coating. Couldn't find any residue with a magnifier after using the tape, but have no idea whether it affects lens coating. Does anyone have any experience with using Scotch tape in this way or any ideas about it?
  2. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    Oh god that sounds like madness mate... I'd leave well alone
  3. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    use traditional lens cleaning prodedure, its less panic riden!
    i wouldnt stick sticky tape to my lenses....
  4. martynk
    martynk
    Don't know if Scotch tape residue could damage the lens coating, but trying to remove any residue certainly could! Try the Lenspen - very good product & easy to carry in a pocket/bag.
  5. ptek
    ptek
    After you remove the scotch tape, clean the lens with scotch tape remover,
    then clean with scotch tape remover remover, then if your lucky, you wont have to use the scotch tape remove remover coating remover :hiya:
  6. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    ive found that baking lenses in a warm oven for 20minutes removes all forms of smeg from the lenses... :suicide:
  7. imichael
    imichael
    Nov 5, 2004
    236
    16
    West Sussex
    I've heard of scotch tape being used to clean sensors in digital slr's, so lenses shouldn't be an issue. It is a specific 'tackiness' level though, if I remember correctly it is the blue 811 tape, but in between AV, photography, motorbikes, kids and dogs I just don't get the time to follow the tape market any more so it might have changed.
    Ian
  8. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
    :oops:
