Cleaning
Discussion in 'General TV Discussions Forum' started by Koen, Mar 10, 2006.
  1. Koen
    Koen
    I need some really good advice on how to clean the screen from my Samsung CRT RP ( no screen shield)
    I just bought it second hand and now I want to clean the whole thing without damaging the screen!
    some say dry cloth others say something else, but there are some nasty finger prints on the screen and I guess a dry cloth doesn't remove them
    please advice
    thanks
    koen:hiya:
  2. M-C-P-M
    M-C-P-M
    Feb 16, 2006
    956
    46
    +107
    Isn't the crt screen a glass one? if so you can clean it with anything! surely? if its like my old crt anyway.
  3. Bat-man
    Bat-man
    Oct 31, 2005
    2,953
    Lincoln
    +547
    But it's a CRT RPTV and the screens are usually acryllic.
    I have found that a damp soft cloth with a little washing up liuid doesn't, in any way, damage the plastic. Finish off with a dry soft cloth.
