Cleaning Z3 filters
Discussion in 'Projectors, Screens & Video Processors' started by neil c, Sep 5, 2005.
  1. neil c
    neil c
    Mar 25, 2005
    537
    +3
    Hi guys,
    I decided to give my Z3 filters a clean last night, as it was a bit overdue.
    I've got the Z3 ceiling mounted, so thats my excuse for taking my time - I was expecting it to be a complete pain to re-align the picture again, fortunately it wan't difficult at all - just keep the lens shift EXACTLY as it was and all should be okay.
    I removed the filters one at a time and used the hoover on both sides if the material by holding it as close as possible to the hoover nozzle. Neither of them looked dusty, but I still gave them a good go. I replaced the Z3, turned it on, and everything worked fine.
    The Z3 manual clearly states that the filters shouldnt be cleaned with water, but is a hoover clean enough? I'm just concerned because the whole ordeal was rather easy and painless, which isn't usually the case with projectors.
  2. sainthalo
    sainthalo
    Feb 24, 2005
    630
    19
    well i do mine every month the same way :)
  3. neil c
    neil c
    Mar 25, 2005
    537
    +3
    Cheers sainthalo, and thanks for the colour filters by the way.
  4. sainthalo
    sainthalo
    Feb 24, 2005
    630
    19
    no probs neil although i wouldn't hoover those before you ask! :smashin:
