cleaning your plasma
Discussion in 'Plasma TVs' started by stuartam_81, Jul 4, 2005.
  1. stuartam_81
    stuartam_81
    Aug 17, 2003
    117
    16
    What do you guys use to clean your plasma screens?
    just a cloth, etc.....
    best regards
  2. Mep
    Mep
    Dec 25, 2004
    9,552
    +472
    do a search mate there are a couple of very long threads (would you believe?) on this very subject
  3. Badger0-0
    Badger0-0
    May 30, 2005
    20,583
    Spaghetti Junction (really)
    +1,921
    Daz scouring powder :smashin:
    Works great.
    Joke :smashin:
    Or anything gentle, as in liquid baby soap or fairy liquid or plain water or glass cleaner.
    Or a cloth with a bit of spit :smashin:
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    have a read of the Plasma screen cleaning cloth thread,the 3M/ScotchBrite Micro Fibre one is the best i have found Tesco ahve then for a few quid
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  6. stuartam_81
    stuartam_81
    Aug 17, 2003
    117
    16
    thanks m8
  7. StrongSilent
    StrongSilent
    Jun 27, 2005
    493
    +6
    I use one of those handy chamois pads (with the sponge inside).
    Gets right into the corners and brings the screen up smudge-free.
    A light misting with non-coloured glass cleaner for anything more stubborn.
  8. wonderloaf
    wonderloaf
    Jul 5, 2005
    264
    Hampshire
    +6
    just bought a hitachi 42pd7200 from richer sounds, they recommend a Spontex cleaning cloth, bright green in colour, available from sainsbury, tesco, etc. don't use anything with a cleaning fluid (ie alcohol or similar) in it as it removes the anti-glare layer on the glass! :(
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    is the spontex that made made foam rubbery one? I would stick to 3M micorfibre (what B&O use) and for nasty marks use steam from kettle to moisten the cloth
  10. stuartam_81
    stuartam_81
    Aug 17, 2003
    117
    16
    ive just got a vileda microfiber cloth, i have used them before for my pc but then they stopped selling them but i guess they started again :)
    best regards
  11. Badger0-0
    Badger0-0
    May 30, 2005
    20,583
    +1,921
    You don't need anything special guys!!!!
    Anything you'd put on a babies butt will do, IMO.
    No doubt someone will prove me wrong though.
  12. chriskenny
    chriskenny
    I use aspecial cloth and liquid that was recommended to me and it is superb. Check out the website for plasmaclean - it wont disappoint!!
  13. chriskenny
    chriskenny
    I use a special cloth and liquid that was recommended to me and it is superb. Check out the website for plasmaclean - it wont disappoint!!
  14. thfccambs
    thfccambs
    Jul 17, 2002
    19,095
    White Hart Lane
    +5,168
  15. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    Hi Hunts1uk,
    Which cloth did you use with that cleaner?
    Andy
  16. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    The Tesco MF towels are quite good for about £1 and much better value than the 3M or Vileda. The best MF towels I have tried come from here www.pakshak.com.
    Unless the screen is very dirty a slightly damp MF towel will remove most dust etc and then buff with a dry one.
  17. thfccambs
    thfccambs
    Jul 17, 2002
    19,095
    White Hart Lane
    +5,168
    Lens cleaning cloth m8.
