Cleaning the screen?
Discussion in 'LCD & LED LCD TVs Forum' started by Rich5ltr, Oct 31, 2005.
Tags:
  1. Rich5ltr
    Rich5ltr
    Aug 22, 2005
    117
    Thames Valley
    Checked out the search and couldn't find an answer to this one so hear goes; what do you all use for cleaning the screen of your LCDs and Plasmas? I don't want to use Mr Sheen, but as the do attract dust like the old glass CRTs they must need wiping off at some time. Any great ideas? Rich...
  2. smallmanongn
    smallmanongn
    Well the screen itself doesn't tend to get dusty like CRTs do.
    Usually in the instructions they tell you what to use to clean the screen if you get a dirty mark on it.
  3. alanwalton
    alanwalton
    You can buy special screen wipes from computer shops
  4. andrewf
    andrewf
    Apr 26, 2005
    1,031
    48
    +28
    Whatever you do DONT USE chemical cleaners like Mr Sheen or dusters you have used in the past with this sort of thing. As far LCD's go at least, they will remove the coating on the screen. Examples exist on the forum of this happening :eek:
  5. Rich5ltr
    Rich5ltr
    Aug 22, 2005
    117
    Thames Valley
    Thanks, working in the IT industry I also thought aboout using PC screen wipes. Any more ideas?
  6. alan_t
    alan_t
    Oct 28, 2005
    604
    +11
    safest i found is to use just a damp cloth.
    some screen wipes aren't designed to be used on LCD screens.
    atleast with a damp cloth, you know its just water.
  7. Derek22
    Derek22
    Jan 25, 2005
    246
    +18
    samsung just supply a soft cloth and recommend you use that simply damp. Cant see why any very soft cloth wouldnt be fine. Just as other people have suggested use a new one and dont let anyone use it for anthing else.
  8. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,480
    Essex
    +1,100
    i got a tub of screen wipes from dixons i think it was..
    storex 100 screen cleaning tissues..
    for cleaning TFT and LCD , Laptop , PDA and scanner
    think they was about £5 for the tub.
  9. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,480
    Essex
    +1,100
    though i havent got a lcd tv "yet"
    i use them on my sony x black lcd monitor
    and on the kids samsungs lcd-tv/monitor...
  10. Rich5ltr
    Rich5ltr
    Aug 22, 2005
    117
    Thames Valley
    Oh... I have some very soft micro-fibre cloths that I use for polishing my car, if anyone touches them they get crucified. They will be fine for the screen! :D
  11. alan_t
    alan_t
    Oct 28, 2005
    604
    +11
    yep micro fibre will be no doubt be the best type of cloths to use.
