Cleaning the PSP
Discussion in 'Playstation Forums' started by dre101, May 18, 2005.
  1. dre101
    dre101
    Dec 23, 2004
    80
    Nottingham
    hi there,
    my PSP has lots of finger prints all over it and it looks awful in my opinion but i don't want to use a screen protector, are there any clothes or liquids i could use? also when playing music is there a way to hold the buttons on the console itself because it is very annoying when a song gets repeated because it is in my pocket and the shoulder button hits my leg
  2. PiePie
    PiePie
    If it's a typical TFT screen then I don't see why you can't use furniture polish. I use it on my TFT. If you don't want to risk it then try using a silk cloth that comes with glasses cases. You may be able to just walk into Specsavers and ask for one.
  3. Simebaby
    Simebaby
    Sep 17, 2004
    769
    +21
    There's a hold button on the PSP... just shove the power switch down (i.e. opposite direction to turning it on / off).
  4. monkeyspank
    monkeyspank
    Feb 17, 2005
    160
    Just use a cotton T-shirt to clean the screen. It works a treat, the hard plastic coating on the screen is easy to clean but don't use a fleece type top as the fibres will scratch it.
  5. Londondecca
    Londondecca
    Dec 21, 2003
    2,081
    +96
    Tesco sell a Micro Fibre cloth for about a £1, buy 2. Dampen (not wet) the first one and wipe the screen and then wipe with the second one. There is also a chemical cleaner called Plexus which is perfect but the MF towels will do 99% of the job for £2
  6. nero0410
    nero0410
    Jan 5, 2004
    12,072
    southwest
    +4,621
    I either use my t shirt, or, a glasses cloth. Both work fine for me
    tris
  7. chrislad
    chrislad
    May 6, 2005
    5,808
    83
    Rep. of Ireland
    +143
    A basic glasses cloth should do the trick.
