Cleaning plugs and sockets on DVD player
Discussion in 'Blu-ray & DVD Players & Recorders' started by MJeeves, Oct 7, 2004.
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    What is the best way of cleaning the sockets and plugs on the back of DVD players, amps and the plugs on cables?
    Is Kontak any good?
    Please help.
    (Sorry if in wrong thread - not sure where to post!)
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    A little bit of IPA should be ok on the metal outsides of them, just make sure none gets inside. I would not clean the insides of them at all, too risky.
  3. monkeylegs
    monkeylegs
    Dec 10, 2002
    79
    Barnstaple, Devon
    Once a year I completely strip my Amp & DVD player down and clean the pcb’s & sockets with electrolube spray and foam cleaner from RS then rinse them it all off with a load of de-ionised water and then to dry every thing I use a combination of the oven (for pcb’s) and a hair dryer. Must admit first time I done it I Sh*t my self wondering if it would all work again, but it does and now I do it every year.
