Cleaning Panasonic PWD6 screen
Discussion in 'Panasonic TVs Forum' started by GAmbrose, Jul 7, 2004.
  1. GAmbrose
    GAmbrose
    Jul 5, 2003
    1,084
    63
    Essex
    +227
    What do you use? Mine has some marks on it which aren't visible when watching it but that you can clearly see when it's turned off.
    What is the best way to clean the screen in your experience?
    Gary A
  2. MrSimba
    MrSimba
    I use computer TFT monitor cleaning wipes - the ones I have in front of me say 'lint free cloths with alcohol free cleaning fluid for plastic surfaces'
    Works a treat and 100% smear free too!
  3. cruncher75
    cruncher75
    Nov 1, 2003
    1,455
    southampton
    +119
    i use a tft/plasma screen spray works fine for me
  4. GAmbrose
    GAmbrose
    Jul 5, 2003
    1,084
    63
    Essex
    +227
    I think thats whats happened to mine actually. Looks like someone has tried to clean it with polish or something at some point and it's left smear marks that I can't shift.
    And no, it wasn't me.
    Gary A
