cleaning northbridge
Discussion in 'Desktop & Laptop Computers Forum' started by jont, Jan 11, 2005.
  1. jont
    jont
    Apr 8, 2002
    4,242
    near Aylesbury
    +545
    Anyone any advice on the best way to clean the thermal-heatsink-grease-stuff from the top of a northbridge chip ... I need to replace the noisy old fan with a silent aluminium heatsink but not sure best way to take old gunk off ?
    thanks
    Jon
  2. nohoper
    nohoper
    I do not believe this is the recommended route, but I have cleaned off thermal grease from a CPU before using just some lint free cloth. That was quite fresh though (I seated it wrong in the first place)
    Assuming that the grease is still "greasy" then you could try this if you get no other more intelligent posts.
  3. klr10
    klr10
    Dec 20, 2003
    801
    28
    Sawbridgeworth
    +27
    Use an aerosol of isopropyl from maplins. Make sure you are grounded with an earth strap while you are poking about in there...
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    If its sill gloopy scrape it off with the side of a credit card.
    If its baked I'd soak it a little with some IPA (Isopropyl alcohol ...not a pint of bitter) applied using a paintbrush then have another go with the credit card.
  5. Big Adam
    Big Adam
    May 7, 2003
    527
    Peterborough
    +4
    ....and to clear any confusion, IPA is available in aerosol and bottle form. Only ever used the aerosol stuff myself (about £5 from Maplin)
    It's an excellent cleaner, lots of uses, not just with PCs.
  6. BALLISTIX
    BALLISTIX
    Oct 7, 2004
    116
    16
    Cotton wool and good old nail varnish remover :smashin:
    I've used/re-used it for over 8 years on CPU's GPU's and NB's does not smear, evaporates rapidly, no problems whatsoever :)
    Regards
    Andy.
  7. klr10
    klr10
    Dec 20, 2003
    801
    28
    Sawbridgeworth
    +27
    Watch out this stuff also melts some plastics.....
  8. Leporello
    Leporello
    I use acetone to clean my CPU and NB, available from high street chemists for less than a quid a bottle. Nail varnish remover is acetone with a trade name and a dafty price. Acetone may interact with some plastics but I've found no such plastic in my PC and I've used the stuff to clear gunk from all sorts of things and paint from a plastic drive cover.
    Go for it.
  9. jont
    jont
    Apr 8, 2002
    4,242
    near Aylesbury
    +545
    Thanks for all your help folks ... went with the nail varnish remover 'borrowed' from mrs t and all cleaned up fine ... had to use an adhesive with the heatsink as no mounting holes so I guess that'll be staying put now ...
    cheers
    Jon
