Cleaning & Maintaining speakers
Discussion in 'Home Cinema Speakers' started by titanax, Jun 10, 2002.
  1. titanax
    titanax
    Hi all...
    How can I clean grime & dust off my speakers? Can I use a damp cloth to wipe the wood surface? I live in a tropical country...so the air is rather humid. Someone suggested wood wax...is that a good alternative?
    How about the rubber around the cone and the cone itself? There is a metal ring inside the cone, how do I clean that?
    Thanksx
  2. Guest
    Mr Titanax,
    My dear sister sends me a few cans of Mr Sheen spray polish every other month. I also live in a fairly humid country and Mr Sheen works wonders on my old Castle speakers.
    I normally clean them once in the morning and then again before bed time. I find that the faster you rub it with a polishing cloth, the better the effect. The shine lasts that much longer.
  3. john87
    john87
    Another wind-up. They are minorly funny, but so little it's not worth the time it takes to read them.
  4. Guest
    Master 87,
    Thank you for taking the time to read my comments. I see from your title you are the youngest member here. May I suggest that as such, its past your bed time.
  5. titanax
    titanax
    Hi Alfred,
    Thanks for the advise, I will try out the wood wax. How about the rubber around the cone? and the cone itself? Can I apply wax on a piece of cloth & wipe them?
    The metal piece within the cone is the driver right? Can I use anything to clean that?
    Thanks a million ! :)
  6. Guest
    You are very welcome my boy.
