Looking at my lenses on my BG801S last night I noticed a small smudge on one, about the size of the dog's nose. They are also a little dusty. Before I give them a buff up is there any advice I should follow? I was intending to use a dry, newly washed duster but if there is a recommended cleaning solution I'd rather use that. Thanks, Mark.
Hi, If you have to clean the lenses then you should use a good lens cleaning fluid and lens tissues from a camera store. Brian
My advice is don't unless it really bugs you. the front element of ALL CRT lenses will be plastic and they are so easy to scratch they are far softer than camera lenses use a very soft brush, I've found the best are the big blusher brushes from Boots. to get rid of the bits of dirt. A lint free soft cloth and HUFF You can use a 50/50 mix of distilled water and industrial methelated spirits with 1 drop of washing up liquid per litre. NEVER EVER use tap water or spit.
I used the same mixture as Roland just suggested (I got the idea off Gordon Fraser's website). It worked well and the lenses look great inside the projector. Be careful not to rub the coating off. Before using the mixture and Jessop cleaning cloth I used blew off as much stuff as I could with one of those plastic lense blowing thingies. You don't want to rub any grit into the lense and stratch it.
Despite the dust on the lens and the small smudge mark (dog now banned from HT room) the picture is actually very good. I think I may just leave them alone. I seem to have a knack for making things worse whilst trying to improve them. Nearly flooded the HT removing "unused" heating pipes. Thanks for the advice tho', Mark.
