Cleaning lenses and screens
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by sachin, Jan 3, 2007.
  1. sachin
    sachin
    Apr 27, 2006
    190
    16
    Happy new year everyone,
    My first post of 2007 is about how to clean the lenses and lcd screens of digital cameras and camorders. My camera's lens is a bit "foggy" around the edges and I didn't want to clean it incorrectly. Are there any suitable products one can buy and what should we avoid?
    Sachin
  2. macc70
    macc70
    Feb 13, 2006
    5
    Hi You should try Jessops or similar as they have lens cleaning pens and cloths. I havent used the pens but the cloths are great.These are only a couple of pounds and last really well. MAKE SURE YOUR LENS/SCREEN HAS NO PARTICLES ON WHICH CAN CAUSE SERIOUS DAMAGE BEFORE YOU USE. In the past I have used cotton buds to clean in the corners which is your major concern Hope this helps
