cleaning lens on PS2
Discussion in 'Playstation Forums' started by backtothefuture, Feb 3, 2003.
  1. backtothefuture
    backtothefuture
    would a normal CD lens cleaner be ok for the above ? ie a cd cleaner with a brush on it...
    also do you guys regularly get rid of dust in the PS2 vents ,using a hand held vac ?
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Yes to both. Although I have a mini techie sad geek vac for the latter.
    Neil.
  3. backtothefuture
    backtothefuture
