Cleaning lazer.
Discussion in 'Blu-ray & DVD Players & Recorders' started by paddy2, Jun 15, 2004.
  1. paddy2
    paddy2
    May 7, 2004
    46
    :clap: I own a Panasonic dme r30 Ive had it for about 14 months with no problems.I have been thinking one of these days I will probably have to clean the lazer due to deteriating picture quality.Has anyone used a cleaner on a Panasonic recorder,and could they recommend one to me to buy, just in case I need it.Also is it possible to clean the lazer manualy by taking the top off.I have always liked cleaning things manualy,in the old vcr days I always cleaned the video heads manualy,but I dont know if this is possible with dvd recorders.
    Paddy2.
  2. dicky
    dicky
    Apr 8, 2004
    165
    Cambs
    Personally I would buy something like this
    http://www.directdistribution.org/item881.htm
    Rather than taking the top off and cleaning manually, theres a bit of a difference between a manaul VCR clean and a DVD/CD.
    Regards
