Cleaning issues
Discussion in 'Projectors, Screens & Video Processors' started by spikerules, Aug 9, 2005.
  1. spikerules
    spikerules
    My replaced 7700 is showing up with the same blotches as my previous 7700. This seemed to happen after cleaning the lens with compressed air and a lens cloth. The blotch gets bigger when I increase the image size, but stay in the same place when I invert the image. Is this dust inside the lens or is it finger print marks?
    Its strange because the blotches are in the same place as before only a bit higher up the screen.... please help as I'm really regrating going the PJ route now:(
    PS other than compressed air and lens cloth is there anything else I can use to get the blotches out? Like a special liquid of some sort?
