Cleaning Gloss Black speakers
Discussion in 'Home Cinema Speakers' started by Palladio, Apr 27, 2007.
  1. Palladio
    Palladio
    Sep 11, 2003
    1,208
    Essex, UK
    +143
    I've got some M&K speakers and SVS sub on order in gloss black and was just wondering what people do to keep them clean and protect them.
    Does anybody use car polish for the job ? I've got some of the Zaino range of polish which would seem ideal for the job and a cleaning up with a clay bar should do wonders for any scuff marks.
  2. KelvinS1965
    KelvinS1965
    Jan 3, 2006
    17,077
    +8,026
    If it's just sticky finger marks or similar, then 'Fast Glass' used sparingly works well on all sorts of glossy finishes.:thumbsup: Good deal on your M&Ks I saw from the other thread.:thumbsup:
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    I was under thje impression that M&K never made glossy black versions of its speakers and that that glossy ones were the dodgy knock off from China. I might be wrong here so perhaps soemone else could clarify this.
  4. KelvinS1965
    KelvinS1965
    Jan 3, 2006
    17,077
    +8,026
    See the link below, this clearly shows shiny versions:
    http://www.mksound.com/xenon1.php
  5. Palladio
    Palladio
    Sep 11, 2003
    1,208
    Essex, UK
    +143
    I've got some Fast Glass somewhere. I'll give it a go.:thumbsup:
    The speakers I demo'd in my local HiFI shop certainly looked like the ones in Kelvins link and definitely sounded the dogs dangly bits.
  6. fire boy
    fire boy
    Dec 14, 2004
    285
    London
    +7
    Does anybody use car polish for the job ? I've got some of the Zaino range of polish which would seem ideal for the job and a cleaning up with a clay bar should do wonders for any scuff marks.[/QUOTE]
    I did read somewhere that one manufactuer uses mer car polish on there gloss black speakers before boxing up
  7. Hamslay
    Hamslay
    Jan 22, 2006
    351
    Bedfordshire
    +13
