Cleaning CRT lenses?
Discussion in 'TVs' started by nathan_silly, Sep 19, 2003.
  1. nathan_silly
    nathan_silly
    Is it ok to use spectacle lens cleaner on the CRT lenses? (inner and outer sides)
    I guess this will cover the LCD PJ, CRT FP & CRT RP forums.
  2. mammoth
    mammoth
    Feb 25, 2003
    121
    16
    birmingham
    Nathan, you might be better off using neat alcohol or something that competely evaporates and doesnt leave a residue (think of halogen bulbs)
  3. nathan_silly
    nathan_silly
    Lens cleaner doesn't leave a residue. I'm thinking it should be OK.
  4. bobones
    bobones
    Jan 15, 2002
    453
    +7
    Isopropyl alchohol can be bought from a chemist for a couple of quid, and it is often used for delicate lens cleaning jobs. I've used it for cleaning laser lenses and the like. Wouldn't like to recommend it for RPTV in case the lens has a coating that is sensitive to it. Some spectacle cleaners contain anti-misting agents, so I'd be careful there too.
  5. Paul D
    Paul D
    Dec 27, 2000
    2,620
    Manchester
    +391
    Courtesy of www.convergent-av.co.uk ;)
  6. bobones
    bobones
    Jan 15, 2002
    453
    +7
    I've just checked the label on the of bottle Isopropyl alchohol bottle I have: 100ml, bought in Apr 1999 from a local pharmacy for about £2-£2.50. I remember they asked why I wanted it, and I explained that it was to clean the lens on a cdrom player and that was that.
    If chemists don't sell it now, I think you'll find that some video/audio tape head cleaning products are just solutions of IA and distilled water.
  7. nathan_silly
    nathan_silly
    I've just cleaned the lens- only used a drop per lens- they weren't that dirty- just a couple of splodges of stuff. Also noticed some splodges of stuff on the mirror too, and a couple of smears. Strange as I cleaned the mirror last time.
