Cleaning cloth with TRV22/33
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Erpland, Oct 2, 2003.
  1. Erpland
    Erpland
    Can you use the cleaning cloth supplied for cleaning the LCD for the lens as well? it feels a bit rough and no mention in the manual.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    Why take the risk?
    If you do damage the lens it is far more expensive to repair than just going to a camera shop or opticians and buying a lens cloth.
    I play it even safer and have a filter permanently attached to the lens for protection. If that get damaged throw it away and buy a new one for a couple of quid. If left attached the lens never needs cleaning.
    Mark.
  3. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    ditto.......me too
  4. torrent
    torrent
    ditto..ditto...you can get a UV filter from Jessops for around £10 - 15 (depending on thread size you need)
