Cleaning air filters - how often?
Discussion in 'Projectors, Screens & Video Processors' started by StephenR, Aug 3, 2001.
  1. StephenR
    StephenR
    Jan 2, 2001
    296
    16
    Warrington
    I have had my Sanyo PLV-30 projector for a few months now and was wondering how often the air filters should be cleaned? Advice would be much appreciated.
  2. Paul O Hale
    Paul O Hale
    The area of the filters of the PLV30 are very small for the amount of air that passes through them, I would clean them about once a month to keep things right.
  3. Paul O Hale
    Paul O Hale
    Just have a look at your filters now, that will give you a time frame for cleaning they only take seconds to remove unless your installation is awkward.<br />If they are clear,well then you can work out a longer filter cleaning interval for the machine.
    I've seen PLV30 filters look like the inside of a full vacuum cleaner bag after only three weeks so that's why my time errs on the very cautious side.
    Regular two minute cleaning vs lamp or panel failure!<br />what would you do?.
  4. StephenR
    StephenR
    Jan 2, 2001
    296
    16
    Warrington
    Once a month? <img src="eek.gif" border="0"> I was thinking more like once every six months! Any other PLV-30 owners care to comment as to how often they clean theirs? Thanks.
