Cleaning a Tosh 36" picture frame telly.......!
Discussion in 'General TV Discussions Forum' started by Stevie G, Jul 7, 2002.
  1. Stevie G
    Stevie G
    May 2, 2002
    638
    +34
    Sorry guys, probably a silly question, but I've lost the manual that came with my telly a few months back! I'm sure I remember reading that you shouldn't using polish and things like that one it, but I can't remember what it suggested! What's the best way to clean it (just like remove dust and marks). Can I use a cloth dipped in warm water and washing up liquid?
    Thanks......
  2. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Plain warm water will be fine. ring out cloth till only damp to touch.
    Washing up liquid could contain detergent which can effect the finish.
  3. Stevie G
    Stevie G
    May 2, 2002
    638
    +34
    OK, thanks. That's what I wanted to be sure about.....done't want to damage it!
    Every few weeks should do shouldn't it?
  4. Doubledoom
    Doubledoom
    Polish can cause static.
    I use glass cleaner. As for frequency, it tends to be about every 3 days. However, i have two young children. Enough said.
  5. billduff
    billduff
    Mar 17, 2002
    275
    16
    Just to the right of civilisation
    I use the Anti-Static screen cleaner you can get from any good Computer shop (or lift from work).
    Don't go for the cheapest stuff though. The stuff in a silver and blue can (can remember itname ScreenClens or something like that) is the better of the couple i've tried.
  6. Stevie G
    Stevie G
    May 2, 2002
    638
    +34
    Thanks guys.....I know not to let Mr Sheen near it now then.....!
